Author Topic: Surface Planes and Forest Tree Pro  (Read 8242 times)
thearkitec
« on: January 19, 2011, 12:11:38 am »
Im finally using the surfaces due to site conditions... I see how the trees attach to the surface...
My problem...
I need to have each group move down in the Z direction slightly.  They look like they are hovering over the surface...
When I try moving them down after attaching to the surface, I see they move down in viewport but render as if they havent moved.
The only option I see the Z direction offset is under the Geometry Tab. That doesnt seem to do anything either...
Is this not an option?
Thank you,
Arkitec
Re: Surface Planes and Forest Tree Pro
« Reply #1 on: January 19, 2011, 04:31:45 pm »
What type of objects are you using: billboards, meshes or proxies ?, what render engine ?
I just test the Z Offset parameter, and it seems to work fine. Besides it, for Custom Objects you can move the pivot point of the source object.
Please, post a test scene to check the problem.
thearkitec
« Reply #2 on: January 19, 2011, 09:14:35 pm »
The objects are billboards... Custom Billboards but billboards.
Using Max 2011 with Vray Sp1.5 64 bit machine.
« Reply #3 on: January 19, 2011, 10:00:37 pm »
Ok, please post a test scene using your billboards.
If that helps, i've attached my own test. It uses Geometry->Z-Offset in Max 2011, VRay 1.5 SP5, Forest 3.4.
thearkitec
« Reply #4 on: January 19, 2011, 10:42:03 pm »
Ok, well I will chalk this one up to user error...
Typically, I move the line associated with Forest objects... which in turn moves the trees.. If I move the Forest tree objects, they stay in the same position.
Z depth distance does work when attached to a plane...  My problem i didnt catch.. I had multipe billboars per object and didnt realize i could move them independently from each.. Therfore, looked like it didnt change... Once I changed all three in the z depth.. all worked...
Thank you for the responses though...
Arkitec
