Author Topic: Forest Pro 3.4.1 update  (Read 9346 times)
Peter Guthrie
« on: January 31, 2011, 11:55:21 am »
"- Fixed potential memory corruption in VRay 2.0 when using high-poly objects."
Can you elaborate on this bugfix? I have noticed occasional memory issues with vray 2 where the memory usage gets very high when really it shouldnt. Just wondering what issue you found, and fixed?
thanks for a great product!
Re: Forest Pro 3.4.1 update
« Reply #1 on: January 31, 2011, 05:22:00 pm »
Yes. It seems the procedure that we use to create the vray instances from meshes, was creating some memory instability in VRay 2.0, although it was working fine in VRay 1.5. We don't know if it would be a VRay issue or our fault (everything in the Forest code seems to be correct).
Unfortunately, the crash it is not easy to reproduce. We needed to run automatic tests for several hours, introducing small changes in the code on each cyle, to find what it was the problem.
Anyways, we have included a workaround in Forest 3.4.1 that must solve this issue. As soon as Vlado will be back on the Chaosgroup forum, we will send to him all the information that we have collected in our tests.
Peter Guthrie
« Reply #2 on: February 01, 2011, 09:23:13 am »
« Reply #3 on: February 01, 2011, 06:02:16 pm »
Yes, it seems that VRay 2.0 cannot handle well the overlapped instances. But this is a issue different from the problem fixed in Forest 3.4.1.
