Author Topic: objects along a spline with different heights of the vertices.  (Read 6541 times)
Martin
« on: September 11, 2012, 07:26:24 pm »
Is it possible to align objects along a spline if the spline has a curve or different heights of the vertices.?
Re: objects along a spline with different heights of the vertices.
« Reply #1 on: September 11, 2012, 07:44:09 pm »
Yes, switching to Custom Edit mode and using Tree Editor->Creation Tools->Along a path:
http://www.itoosoft.com/forestpack/reference/refedition.php
Martin
« Reply #2 on: September 11, 2012, 08:31:05 pm »
Thanks.
Why is it that the number of objects got low after I pushed "create" folow path.
Before I used the follow path (custom edit) the bushes was aligned close to each other the hole way around the spline. ?
Martin
« Reply #3 on: September 11, 2012, 08:43:59 pm »
I solved the problem with the spacing..
Martin
« Reply #4 on: September 11, 2012, 09:00:53 pm »
I get an error message with forest pack trying to render the image after aligning the objects.
See error message here: https://www.dropbox.com/s/f4mlhr87qsbsbem/error.PNG
« Reply #5 on: September 12, 2012, 12:08:00 am »
Strange issue, for some reason Vray cannot generate the instances of the Forest object.
Does it happen only with those items ? What Max and VRay version do you use ?
Please, try to reproduce the problem in a separate scene, and send us the files to support@itoosoft.com. We will check it.
