Author Topic: Huge area of grass  (Read 22704 times)
Ignacio
Huge area of grass
« on: February 24, 2025, 05:10:27 pm »
Hi guys,
I've been following this tutorial (https://www.youtube.com/watch?v=0ldSIeMlg48) step by step, and when I get to applying the second ForestPack, if I visualize it as a point cloud, it moves off the surface. I've tried applying an XForm, but it doesn't seem to fix it. Any ideas? Thank you for your help. Images are attached.
Thank you as always
Re: Huge area of grass
« Reply #1 on: February 25, 2025, 08:36:26 am »
Hi Ignacio,
The Forest Pack plug-in uses the item's Pivot Point position - most likely, it isn't "centered" in your case. To fix this: select the inner Forest object, go to the Hierarchy tab, and under Adjust Pivot, select Affect Pivot Only. Move the Pivot Point to the desired position (using the Align tool - Ctrl+A can be very handy to do this automatically).
