Author Topic: Anim - update for each frame - fstorm  (Read 2972 times)
ben_img
« on: November 03, 2021, 10:17:46 am »
I have some ForestPro objects using "align to camera"
i'm using fstorm renderer, and when i render a sequence of an animated camera, it doesn't refresh for each frame. Meaning the objects are facing what they were on the frame 0.
I'm not sure if it's something to do with fstorm, or forestpro.
And how could i force the update for each frame
any clue ?
Re: Anim - update for each frame - fstorm
« Reply #1 on: November 03, 2021, 10:33:18 am »
Hi Ben,
I assume you are using Forest Pack 7?
We recently identified a problem with several renderers that are using our API to add support for Forest Pack, including Fstorm (as well as Redhsift and Octane. It would appear that there is an incorrect value in the implementation of these renderers with the Forest API. Although it was not important with FP6, this value is critical for FP7.
This must be solved by the renderer's developers, we'll get in touch to let them know.
Meanwhile, in Forest 7.2.1 beta, we have re-introduced the "Camera" parameter. It lets you assign a Camera manually, instead to get the view settings automatically.
With a Camera assigned, clipping and the other features should work fine.
ben_img
« Reply #2 on: November 03, 2021, 10:51:16 am »
Thanks for your reply.
Using forest 7.1.1 indeed
i'll try the beta product.
all the best
ben
