Author Topic: Tiling is visible. How can I get rid of it?  (Read 2979 times)
MrpepeLepeu
« on: February 01, 2020, 10:31:40 pm »
Please see image below.
How can I get rid of the tiling if the density is high?
Is there a procedural random function instead of an image?
Using 3ds max 2020 and Forest 6.2.2
Re: Tiling is visible. How can I get rid of it?
« Reply #1 on: February 03, 2020, 09:07:37 am »
You have many options how to scatter on large areas and fix tiling that comes from default distribution modes.
1. Add Random translation per item using Transform Rollout:
2. Use custom procedural map, as You asked.
3. Use particle flow as distribution:
And probably some other methods to fit Your needs.
Anyway I would recommend You watching this tutorial which explains ForestPack Distribution settings and shares many useful tips.
MrpepeLepeu
« Reply #2 on: February 03, 2020, 04:56:46 pm »
Thank you.
I can't help to wonder why these options are not the default if they seem to work better than images.
« Reply #3 on: February 03, 2020, 05:13:41 pm »
Images provide many quick presets from man made grids to natural scattering to clumps and streaks etc... without the need to go to material editor to fiddle with parameters.
RealViz
    • RealViz
« Reply #4 on: February 07, 2020, 01:18:01 pm »
Bitmaps are fantastic because you just need to remember a few variations and know exactly what you will achieve. In addition, 99% is enough with just prepared bitmaps.
