Author Topic: Animate Direction of Lights with Effect or Map  (Read 3085 times)
rob-bs
« on: October 08, 2023, 09:47:05 am »
Hello all,
I am working on a scene in which I'd like to animate the orientation & movement of a large number of V-Ray Lights using Forest Pack. I am scattering the lights along a spline using the "path" distribution method, and I am controlling the orientation of the lights with the transform controls.
There are a few ways I can animate the movement of any object - for example, with an animated noise map in the transform roll-out, or by using an effect (3-axis look-at effect) combined with an animated helper object.
These techniques work fine for normal geometry, but it seems that Forest Pack does not behave the same way when the reference objects are V-Ray Lights. In my viewport before rendering, the lights will move according to whatever technique I apply, but at render time the Forest Pack-generated lights are static, and they do not change according to the movement I am previewing in the viewport.
Is this a known limitation, or am I doing something wrong?
I am using Forest Pack 7.1.2. I know that the Light-scattering features of Forest Pack have been updated since this version, but my studio has not updated to the latest versions yet.
Is this even possible, to animate the direction & orientation of the lights? Thanks!
Re: Animate Direction of Lights with Effect or Map
« Reply #1 on: October 09, 2023, 09:16:05 am »
Upon my quick test, the mentioned setup works just fine in the latest version (FP 8.2.4 & V-Ray 6 Update 1.2) - since the Forest Pack 7.2.1 we added support for native light instancing in V-Ray (which requires V-Ray 5.2 or greater).
rob-bs
« Reply #2 on: October 09, 2023, 05:57:18 pm »
Ok, great! Thank you for the info. I've been meaning to update our systems, so this is just one more reason to do so. Thanks again.
