Toggle navigation
Login
Register
Forest Pack
Forest Pro (*)
Odd results with hanging chains
« previous
next »
Print
Pages: [
1
Author
Topic: Odd results with hanging chains (Read 4116 times)
iCreateLtd
Full Member
on:
October 10, 2023, 01:57:14 pm »
Hi all
I'm having a weird issue with a hanging chain I'm trying to create.
What I don't show in the video is I've created a long chain base object & the pivot is at the top.
It's doing the opposite of what it's showing.
Any ideas why?
https://youtu.be/0uHdNJjvw7g
Logged
ITOOSOFT
Hero Member
Re: Odd results with hanging chains
Reply #1 on:
October 10, 2023, 02:04:49 pm »
Adjusting its
Direction
settings under the
Surface
tab (which is set to 100 by default) to the Surface's
Normal (0)
should help. If needed, you can "flip" the surface.
Logged
iCreateLtd
Full Member
Reply #2 on:
October 10, 2023, 02:08:23 pm »
Sorry, another thing I should have mentioned is that I'm using a path for distribution and nothing's plugged into surface.
Maybe I should send a file of just the chain FP
Logged
iCreateLtd
Full Member
Reply #3 on:
October 10, 2023, 02:36:03 pm »
Hi Michal,
I've PM'd you a link to the max file of just the chain FP.
It's best viewed in alpha mode when rendering.
If you can take a look that'd be great.
Logged
ITOOSOFT
Hero Member
Reply #4 on:
October 10, 2023, 03:12:31 pm »
That's because of using the
Proxy
Display mode - items used for this mode have the Pivot Point placed at the bottom. Instead, your Custom Object has the Pivot Point placed at the top. Using the
Points-Cloud
Display mode for the preview would be recommendable. I hope this clears it up.
Logged
iCreateLtd
Full Member
Reply #5 on:
October 10, 2023, 03:20:15 pm »
Doh!!
That's great, thanks for the help
Logged
Print
Pages: [
1
« previous
next »
Forest Pack
Forest Pro (*)
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
