Author Topic: forestpack + Xref Scene + dummy link = scale issues  (Read 3197 times)
leo.surrealismo
    • surrealismo
« on: November 20, 2019, 01:42:28 pm »
hi,
I have a master scene file where I put various Xref scenes linked to dummies so I can locate them on the exact position on the scene.  I have a forest that anytime I rotate the dummy, change his scale.
is it a bug?
Re: forestpack + Xref Scene + dummy link = scale issues
« Reply #1 on: November 20, 2019, 03:44:07 pm »
Hi Leo,
In theory, that should be something already fixed (in my quick test with the FP 6.2.2, using the XRef Scene & Bind to a Point Dummy object behaves as expected when moving and rotating that). Would you mind to specify your actual software configuration (3ds Max, FP & renderer versions used)?
If possible, please feel free to send us your scene and we'll have a look at it here. Ideally, would you mind to try to reproduce the problem with a minimal scene and send us such a scene?
Thanks in advance for any further comments on this issue you can share about it with us / our user community (in case some user(s) will run into similar troubles).
leo.surrealismo
    • surrealismo
« Reply #2 on: November 20, 2019, 05:29:57 pm »
there must be something wrong with my file.   When I simplify the scene, it behaves correctly.
I´m using 6.2.2
