		Forest Pack => Forest Pro (*) => Topic started by: Gintautas on January 18, 2024, 10:01:14 am
				As it is now, this effect starts at 0 frame, and you can adjust animation length using SecondsToAnimate. But you cant adjust it to start on frame 50, for example.
 I tried just randomly grabbing, a snippet of a script from other effect. But at best it doesn't cause any errors, and does nothing in the end.
 Here is a mildly edited effect:
 int randCounter = randomInt(startFrame,endFrame);
 vector offsetMapAmount = evaluateTexture(OffsetMap,fpItem.distUVW);
 real randomStartTime = randomReal(RandomStart, RandomEnd)+(OffsetStart*offsetMapAmount.x);
 real TimeInSecs = Max.time/4800.0;
 real ActiveTime = if(TimeInSecs>randomStartTime,TimeInSecs-randomStartTime,0.0);
 real timePosition = min(1,ActiveTime/SecondsToAnimate);
 real newScale = evaluateCurve(XYZ_Scale,timePosition);
 fpItem.scale = [newScale,newScale,newScale];
 If you want to adjust the time at which the animation starts and ends, you can modify the Animate Scale by Age effect, for example, in the following way:
 real randomStartTime = randomReal (RandomStart, RandomEnd)+StartTime;
 real timePosition = min(1,ActiveTime/(EndTime-StartTime));
 fpItem.scale.z = evaluateCurve(Z_Scale,timePosition);
 real XYScaleValue = evaluateCurve(XY_Scale,timePosition);
 fpItem.scale.x = XYScaleValue;
 fpItem.scale.y = XYScaleValue;
