Author Topic: how do I remove references to forestpackpro2.dlo xshadow?  (Read 4850 times)
Kai
« on: June 18, 2012, 05:26:39 pm »
I have an old scene that claims to be using xshadow yet I have no forest objects and no lights. How do I get rid of this plugin reference?
yuv
  • iToo Software - CEO
    • Itoo Software
Re: how do I remove references to forestpackpro2.dlo xshadow?
« Reply #1 on: June 18, 2012, 05:58:36 pm »
Try to merge all objects in a new fresh scene, this should eliminate all old plugin references.
Daniel Quintero
Itoo Software
www.itoosoft.com
daniel@itoosoft.com
Kai
« Reply #2 on: June 18, 2012, 06:36:56 pm »
That was the first thing I tried but the reference is still there when I open the file. If I check File properties/contents, forestpackpro2.dlo shows up under "used plugins". But under summary info/plug-in info, it doesn't show up.
Does xshadow attach to anything besides light objects? there are no lights in the scene.
thanks,
Kai
Kai
« Reply #3 on: June 18, 2012, 11:49:06 pm »
I finally managed to get rid of the xshadow reference by creating a new light and set the shadow type to shadow map.
« Reply #4 on: June 19, 2012, 05:15:45 pm »
I just found in our e-mail archive a message from Autodesk about this issue. This seems a common behaviour of Max with the shadow plugins; it creates a 'dummy' shadow reference, even if XShadow is not used anymore in the scene.
They provided us a script to fix the missing reference, but probably it is a bit complex for the end users. Your method has the same result and it is much more simple.
