Author Topic: Can't seem to exclude areas fully with Splines :(  (Read 5495 times)
Adam86
« on: July 04, 2019, 01:08:45 pm »
Hi - I might be missing something obvious however I can't seem to get clean divisions between grassed areas and clear. I am using a closed splines to exclude areas, this is working in most areas but not all. i'm also getting random areas where it gets added.
« Last Edit: July 04, 2019, 01:12:02 pm by Adam86 »
Adam86
Re: Can't seem to exclude areas fully with Splines :(
« Reply #1 on: July 04, 2019, 01:14:17 pm »
apologies, i found the fault - the splines i were using are from CAD, and closer inspection found there to be some extra splines along side the closed splines. by removing these extras the cuts are now perfect.
« Reply #2 on: July 04, 2019, 01:16:18 pm »
Thanks for letting us know You found the solution and shared that with us.
