Author Topic: Animated surface - follow uv  (Read 4159 times)
LO1254
« on: July 26, 2018, 01:39:42 pm »
Hi, we just updated to the new forestpack 6.1.1, we noticed that somehow forest isn't properly following a animated mesh by its uv map.
This used to work before, are we missing something?
Test scene in attachment - max 2017
Re: Animated surface - follow uv
« Reply #1 on: July 26, 2018, 05:40:19 pm »
I opened Your scene with FP 5.4.1 and FP 6. I see no difference. Could You please explain the issue in more detail ?
LO1254
« Reply #2 on: July 27, 2018, 02:57:01 pm »
Thank you, Sure!
From frame 27+ the number of instanced boxes starts changing, making them jitter around the surface.
Are there any settings we are missing to make them static on the surface?  (without using a particle flow system)
« Reply #3 on: July 27, 2018, 03:50:02 pm »
I still see exact same result on FP 5.4.1 and FP 6.
I could only advice using particles workaround.
