Author Topic: Corona + FPP  (Read 4822 times)
IT1371
Corona + FPP
« on: December 07, 2017, 10:59:30 am »
I hate this odd issue that when I open a scene and hit render right away Forest will refuse to load his license from the license server.
Only once I select a forest object and hit render again it will work.
Any idea how to get rid of this annoyance?
Using Corona Render 1.7 - will update to hotfix 2 by the end of the week and 3dsmax 2016.
ForestPro - latest.
Windows 10 Fall Update 1709 (if it makes a difference)
Re: Corona + FPP
« Reply #1 on: December 07, 2017, 03:17:17 pm »
Sorry to hear you're facing these troubles. I would suggest you set the IP of the licensing server "manually" rather than finding it automatically. That can be done during the installation or by using the "Change License Mode" wizard after setting Network license mode in the Configure the Network License window.
In case, you'll be still facing troubles with it, please enable the debug mode in the License Server and send us the log file from the Itoo Software License Manager - License Server tab - View Log... to analyze it here.
Thanks in advance for your collaboration, your feedback is very important to us.
