Toggle navigation
Login
Register
Forest Pack
Forest Pro (*)
distribution map
« previous
next »
Print
Pages: [
1
Author
Topic: distribution map (Read 2678 times)
djibvongenf
Newbie
distribution map
on:
May 15, 2022, 04:11:58 pm »
Im having a precision issue with a distribution map. Any idea why the grass preset does not follow the border (in yellow)?
Distribution map is B/W of 10k pixel.
thank you
Last Edit: May 15, 2022, 07:14:57 pm by djibvongenf
Logged
RealViz
Sr. Member
Re: distribution map
Reply #1 on:
May 16, 2022, 08:00:52 am »
It is much better to use edge mode for this.
https://www.itoosoft.com/tutorials/edge-mode
Logged
djibvongenf
Newbie
Reply #2 on:
May 16, 2022, 08:18:50 am »
Hi,thank for the reply,
Unortunately the ground is not flat
Logged
RealViz
Sr. Member
Reply #3 on:
May 16, 2022, 08:29:40 am »
It doesn't matter. Just put the object in surface and check edge mode in area spline. Or split the surfaces themselves with shapemarge and then check edge mode in area and enable in surface area.
Logged
djibvongenf
Newbie
Reply #4 on:
May 16, 2022, 10:29:17 am »
Once again thanks a lot cause it works amazingly.
Logged
Print
Pages: [
1
« previous
next »
Forest Pack
Forest Pro (*)
distribution map
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
