Author Topic: Painting crashes max  (Read 2847 times)
FD7518
« on: March 31, 2023, 04:27:34 am »
If you paint trees, then modify the terrain like using push/pull.  Then go back to itoo and try to add more painting it crashes max  Thanks
Re: Painting crashes max
« Reply #1 on: March 31, 2023, 09:07:15 am »
I’m sorry to hear you're facing these troubles. I've done some tests with this feature, but up to now I can't reproduce any issue(s) here. Can you please save and send us  the minidump file of the crash? Ideally, if you'll be able to reproduce it on a minimal scene, which you can send us, that would be great.
Thanks in advance for any further comments on this issue you can share about it with us / our user community.
RealViz
    • RealViz
« Reply #2 on: March 31, 2023, 09:23:48 am »
It usually happens that Max crashif we draw in perspective and the brush goes too far or to the horizon. What I mean is. Have you tried drawing in Orthographic view?
« Reply #3 on: March 31, 2023, 11:08:36 am »
Thanks for your swift reply. I’ve done some additional tests using both Perspective / Orthographic view, but I’m not able to reproduce the mentioned problem. As mentioned previously: “Can you please save and send us  the minidump file of the crash? Ideally, if you'll be able to reproduce it on a minimal scene, which you can send us, that would be great. ”
