Author Topic: Forest object offset from geometry at creation  (Read 6591 times)
SL1712
« on: May 02, 2012, 03:13:05 am »
Hello. I'm having trouble with creating a forest object in one of my scenes. When I create (by clicking on the surface) the forest appears offset from the surface object.
To test this, I started a new scene and made a forest on a plane, which worked. Then I opened my project scene and merged in the working forest and surface, and it became offset.
I'm including a graphic to better demonstrate what is happening.
Any ideas what could cause this?
Re: Forest object offset from geometry at creation
« Reply #1 on: May 02, 2012, 08:38:51 am »
Does it change clicking the "Reload" button in the "Surface" rollout ?, And clicking "Display->Update" ?
I cannot reproduce this problem here. Please, send us a test scene to check it. Tell me also what Forest and Max version are you using.
roysgi10
« Reply #2 on: February 21, 2018, 08:04:37 am »
hi.
exactly same things happen here. attached max file and print screen.
whats wrong?
« Reply #3 on: February 21, 2018, 10:52:41 am »
The distribution itself is correct – as you can double check for example by assigning any Custom Object – or changing the Template used (to for example a Simple 3D Tree). For some reason (might be, you’ve moved accidentally its Pivot Point), the One Plane Template object, isn’t correctly aligned – to fix it, you can delete all content from the forest_templates layer, which will be recreated automatically.
Hope that helps.
roysgi10
« Reply #4 on: February 21, 2018, 12:41:29 pm »
Thanks.
This is actually what I did
