Author Topic: Animation offsets Issue  (Read 4363 times)
Viz_Sci
« on: June 10, 2013, 06:17:46 pm »
Hi all,
I just started using the forest pack and I had a question regarding animation offsets. I am using a custom object of 120 frames. Its two objects that come together and bind. I am trying to create some large offsets so that  when I reach the end some of animations should just be starting and some are halfway through but what I am getting is that all of them finish at the same time. I have set the animation to random samples and set the samples to time offset 30 and  count 4. which should give me 4 loops of 30 frame offset as I understand. But I dont seem to be getting enough offset.
Any tips would be appreciated.
Re: Animation offsets Issue
« Reply #1 on: June 10, 2013, 07:33:09 pm »
Please, be sure the Custom Object has a loop animation. Forest gets the animation samples directly from the Max keyframes, it doesn't generate a loop by itself.
Usually you must adjust the Out-Of-Range curves in the Track view, to get the loop effect.
