Author Topic: Area requests  (Read 3378 times)
George
Area requests
« on: August 28, 2014, 08:38:49 am »
I have 3 area related requests:
  • Include mode for Forest objects - for fallen leaves under trees
  • Override falloff controls per area object
  • A map or utility to save the map for whatever the Forest area mode uses so you can have different material near bases of trees. If it's a utility it would probably have to add a UVW modifier to the surface objects so the projection bounds are correct.
Re: Area requests
« Reply #1 on: August 28, 2014, 09:52:17 am »
Hi, thanks for your suggestions:
Something as this ? http://forum.itoosoft.com/index.php?topic=1347.0
I think there are three options for this. Not sure what it's the best:
- Area->Falloff Affect, as currently does.
- Move Falloff parameters as local properties for each area. It may be difficult to adjust when usign multiple areas.
- Duplicate all falloff parameters within local properties: complex and it would be too much parameters for this UI.
I'm afraid but this would be though to implement,  there are many data to be included in a map: area extent, items positions, scale, diversity, exclusions and much more. And this for each one of the areas.
George
Re: Area requests
« Reply #2 on: August 29, 2014, 02:49:11 am »
I know you can use it as an exclusion area (i'm already using for the purpose in that thread), but i'd like to use FP area objects in inclusion mode aswell.
Fair enough, the affect % is probably enough.
I thought this might be the case. I did have success with VRayDistanceTex, but I have to duplicate the ground mesh otherwise I get a circular reference (because FP uses it as a surface).
Thanks for the quick response!
Re: Area requests
« Reply #3 on: August 29, 2014, 09:18:13 am »
It can be done using Falloff->Invert Curve. You can see it in the last part of the video (the blue grass). This option inverts the Falloff curve effect, switching an exclude zone as include.
