Author Topic: forest doesn't show up on mirrored surface  (Read 2982 times)
lukx
    • lukxCGI
« on: April 27, 2016, 10:09:31 am »
I have problem with forest not showing on mirrored object.There is pavewalk on left and right and only on left side forest is showing. Flipping polygons helps but it's instance object so then I'm loosing forest on other side. So basically something isn't right.
here's the scene
Re: forest doesn't show up on mirrored surface
« Reply #1 on: April 27, 2016, 10:36:42 am »
While using the Mirror tool, I would suggest you to select the Geometry mode (which applies a Mirror modifier whose transformation matrix matches the current Reference Coordinate System setting). This should avoid any "flipped normals" issues.
Hope that helps.
mitviz
    • mitviz
« Reply #2 on: April 27, 2016, 03:06:18 pm »
ahh maybe this was my issue previously too!
Professional architectural renders
