Toggle navigation
Login
Register
Forest Pack
Forest Pro (*)
areas - boundary checking - edge does render AO of the cuttet object
« previous
next »
Print
Pages: [
1
Author
Topic: areas - boundary checking - edge does render AO of the cuttet object (Read 3874 times)
AldingerWolf
Newbie
on:
April 09, 2018, 12:43:48 pm »
hello,
vray 3-60-04 shows the AO of the edge cuttet object.
so far it is all right, the objects gets cut at the edge, but its wrong that i see the AO of the rest of the object that got cut away
problem of FP 5-4-0 or Vray?
Last Edit: April 09, 2018, 12:51:32 pm by AldingerWolf
Logged
Hero Member
Re: areas - boundary checking - edge does render AO of the cuttet object
Reply #1 on:
April 09, 2018, 01:48:08 pm »
Hi. Info from
FAQ about edge
mode:
b) Under V-Ray render settings, increase Global switches->Max transp. levels (default value is 50). Sometimes may be necessary to modify Secondary rays bias also.
Please try this.
Logged
AldingerWolf
Newbie
Reply #2 on:
April 09, 2018, 03:44:46 pm »
you need to activate work with transparency on vraydirt material.
that did the trick.
Logged
Hero Member
Reply #3 on:
April 09, 2018, 04:25:57 pm »
Thank You for posting the right setting.
Cheers.
Logged
Print
Pages: [
1
« previous
next »
Forest Pack
Forest Pro (*)
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
