Author Topic: areas - boundary checking - edge does render AO of the cuttet object  (Read 3877 times)
AldingerWolf
hello,
vray 3-60-04 shows the AO of the edge cuttet object.
so far it is all right, the objects gets cut at the edge, but its wrong that i see the AO of the rest of the object that got cut away
problem of FP 5-4-0  or Vray?
« Last Edit: April 09, 2018, 12:51:32 pm by AldingerWolf »
Re: areas - boundary checking - edge does render AO of the cuttet object
« Reply #1 on: April 09, 2018, 01:48:08 pm »
Hi. Info from FAQ about edge mode:
b) Under V-Ray render settings, increase Global switches->Max transp. levels (default value is 50). Sometimes may be necessary to modify Secondary rays bias also.
Please try this.
AldingerWolf
« Reply #2 on: April 09, 2018, 03:44:46 pm »
you need to activate work with transparency on vraydirt material.
that did the trick.
« Reply #3 on: April 09, 2018, 04:25:57 pm »
Thank You for posting the right setting.
Cheers.
