Author Topic: Areas-Fallof-Density & Scale NOT WORKING on surfaces  (Read 3193 times)
MK3983
« on: July 22, 2019, 05:27:10 pm »
Hi guys,
I'm having trouble with Density and Scale after the latest update 6.22
https://www.dropbox.com/s/pm1xx9lrhd823me/2019-07-22_18-01-25.mp4?dl=0
The above link explains what i mean in the above title.
Any ideas would be much appreciated, otherwise we have to downgrade to 6.21
Regards,
Re: Areas-Fallof-Density & Scale NOT WORKING on surfaces
« Reply #1 on: July 23, 2019, 09:08:56 am »
Would you mind uploading Your file so that I can take a closer look and check it out.
It does work for me:
MK3983
« Reply #2 on: July 23, 2019, 10:13:30 am »
Thank you for your time!
Here it is: https://www.dropbox.com/s/f8d8vborwj0z81q/Dense_Scale.max?dl=0
Regards
« Reply #3 on: July 23, 2019, 11:20:33 am »
Hi Thanks for file. I see You are using Box object instead of Plane.
This did not work on previous FP version either. This is a known "surface" limitation.
Once excess surface is deleted it works as expected:
MK3983
« Reply #4 on: July 23, 2019, 02:24:22 pm »
Thank You very much for your help!
Regards
