Author Topic: install paths  (Read 5889 times)
jonavark
install paths
« on: March 20, 2012, 03:25:57 am »
I have installed 3.81 (x64) and I have noticed that the installer places everything in the /program files (x86)/ folder and nothing in the /program files/ folder. Yet when viewing
http://www.itoosoft.com/forestpack/reference/install.php
It refers to the 64bit folders? Or does this info page only refer to a 32 bit install?
Thanks!
yuv
  • iToo Software - CEO
    • Itoo Software
Re: install paths
« Reply #1 on: March 20, 2012, 08:32:16 am »
Forest Pack doesn't install anything on the c:/Program Files folder on a 64 bit system, because all shared files between 3dsmax versions are 32 bits executables or non-executable (as libraries or thumbnails). Only the plugins itselfs are 64bit binaries.
There is only one folder called <forestdir> with all these common files, pointed by the registry key MainDir and installed by default on C:\Program Files (x86)\Itoo Software\Forest Pack Pro.
« Last Edit: March 20, 2012, 08:36:46 am by iToo »
Daniel Quintero
Itoo Software
www.itoosoft.com
daniel@itoosoft.com
Re: install paths
« Reply #2 on: March 20, 2012, 08:39:51 am »
Anyway, there was mixed references to both paths in the documentation.
I just fixed it, leaving only "C:\Program Files (x86)\Itoo Software\Forest Pack Pro", which is the default path for Windows 64 bit (the most used configuration for Max).
