Author Topic: Arnold Procedurals won't show up in Foret Pro  (Read 10360 times)
hyperviktor
« on: March 21, 2023, 09:35:21 pm »
For some reason I can't post in the Forest Pro section so I just write here - arnold procedural objects in 3Ds max won't show up / render at all in Forest Pro - am I doing something wrong or it's just a missing feature ?
Re: Arnold Procedurals won't show up in Foret Pro
« Reply #1 on: March 22, 2023, 09:43:32 am »
I’m afraid, that the .ass format isn’t fully supported. Because of technical limitations, it’s not showing correctly in the viewport – by using the moment using the Proxy Viewport mode you should at least see the “center” of these items when used within the Forest object(s). On the other hand, these items should render just fine – in case of any troubles, please double-check the “Pivot Point” position of the used object(s).
I hope that helps a bit.
