Author Topic: Green wall - how to fill space?  (Read 3329 times)
TL1895
« on: February 13, 2023, 10:31:32 pm »
I've gotten the grape vertical preset to work but now cannot seem to adjust the density/coverage.
It's scattered on a single surface.  In the attached screen grab the far left area looks correct, but the other areas seem to have holes in the wall.
I can't seem to fill those areas using any of the settings in the Forest object.
I'm new to the se vert presets, so please let me know if there is an easy solution here...
Thanks in advance...
Max2019 + current v-ray
TL1895
Re: Green wall - how to fill space?
« Reply #1 on: February 13, 2023, 11:19:22 pm »
Update: So, I was just too worried the density units was too high...I got the spaces filled, but now there is obvious visible tiling of the geometry...
« Reply #2 on: February 14, 2023, 04:54:44 pm »
Thanks for getting in touch. You might need to adjust the density for the X and Y axis separately, this can be unlocked by unchecking the Lock Aspect Ration option.
If there's still obvious tiling, please try adding some X and Y translation variation from the Transform rollout.
Cheers!
TL1895
« Reply #3 on: February 14, 2023, 05:57:06 pm »
Thanks a lot Paul  :)
I'll give it another try today!
TL1895
