Author Topic: Toolbars resets everytime  (Read 4829 times)
CharlyRT
« on: June 27, 2022, 10:11:33 pm »
Hello there, since a couple of 3ds max versions, some Toolbars resets everytime that 3ds max opens, I have used a Reg file from this forum that deletes iToo toolbars, so I have created my own, the thing is, is there another wat to prevent this?
amitgedia
Re: Toolbars resets everytime
« Reply #1 on: June 28, 2022, 09:06:42 am »
Same question here also, I customized the toolbar, saved it (.cuix files) but everytime i open 3dsmax it resets and i have to load the file everytime to get the customized toolbar
« Reply #2 on: June 30, 2022, 08:42:28 am »
I'm sorry, but we could not solve the problem of toolbars resetting.
As discussed in the other post, the only way is to disble them using the registry trick, and create a customized toolbar using the iToo actions.
If same problem happens with the customized toolbar, i'm afraid we cannot help with that. It seems a Max issue.
CharlyRT
« Reply #3 on: June 30, 2022, 04:17:25 pm »
Thanks for the reply Carlos, like I said, I've used the Reg Trick and create my own Toolbar, so my next question is, how can I restore the old Toolbars? Reinstalling the Plugin solve this? this is in case I want to restore everything.
Best Regards
Carlos Rodriguez
« Reply #4 on: July 01, 2022, 08:35:35 am »
Please use the 'EnableToolbars.reg' attached below.
In case anyone needs it, i include the registry for disable as well.
Be sure to restart Max after applying it.
yeeha68
« Reply #5 on: September 20, 2022, 08:27:41 pm »
This is really silly.  I keep hearing use the "temporary" fix but this has been going on for years. 2019,2020,2021,2022.
Why does every other addon software that creates toolbars work as expected.  I think iToo software is one of the most reliable and worthy tools out there but, COME ON!  Fix this! Please!
« Reply #6 on: September 21, 2022, 08:38:12 am »
We added a workaround in FP8 beta which should restore toolbars to their right position.
It calls to the following Maxscript:
Code: [Select]
cui.loadConfig (cui.getConfigFile())
It can be used with FP7 or RailClone to get the same result. Just run it from the Maxscrtipt window, once Max is initialized.
I hope that helps until FP8 final is ready.
Bobby Parker
« Reply #7 on: October 07, 2022, 05:56:42 pm »
This script seems to put the toolbar back where I don't want them to be. Pulling them off the top bar and running the script puts them back in the top bar.
DT
« Reply #8 on: October 29, 2022, 12:42:00 pm »
Mayba ask Chaos or Corona guys or whatever plugin how they did it, because it seems Itoo is the only one suffering from this, extremely annoying....
« Last Edit: October 30, 2022, 09:08:03 am by DT »
« Reply #9 on: November 01, 2022, 10:03:13 am »
I just asked to them. I hope we can solve this issue soon, in one way or another...
