Author Topic: Follow disp. surf. not working with Vray Distance tex.  (Read 2849 times)
RealViz
    • RealViz
« on: April 29, 2020, 04:49:07 pm »
I want to use vray distance tex. for displace surface, it working with Vray Disp. mod. But the same vray distance tex. not working with FP in effect :-(
attachement: jpg and Max file (2020).
Re: Follow disp. surf. not working with Vray Distance tex.
« Reply #1 on: April 29, 2020, 06:17:55 pm »
Hi!
Thanks for the question. Please take a look at the attached in which I have modifier the Forest Effect slightly. The issue appeared to be related to the fact that the V-Ray Distance Texture does not use UVW coordinates but the effect was using the surface's UVW's to read the texture information. I have updated it so that it now uses the position of the item instead. Please note that in order for this to work, the Forest Object's location should be set to the world origin.
All the best,
« Last Edit: April 29, 2020, 06:20:59 pm by Paul Roberts »
RealViz
    • RealViz
« Reply #2 on: April 29, 2020, 06:44:55 pm »
Thanks! I think that UVW is the problem, but Im not sure. Is there any chance to put this in Efects Lib.?
Thx again
« Reply #3 on: May 01, 2020, 01:00:03 pm »
Glad that helped out. Sure, I think we can add it to the library.
All the best,
