Author Topic: Change XY Plane Local to World?  (Read 5173 times)
RC2463
« on: June 23, 2014, 01:51:00 pm »
I have been struggling with Pointing direction for couple of days already. The problem I am using the same Mesh with different rotations and the forest Pro define the Up Direction by Local Axis. So when I set it pointing up it keeps pointing to the right which is very annoying. I have tried UV Mode but nothing is working. My question is how to change to change it to the WORLD direction. Even tried Xform reset but nothing works!! and if I put a slider to 0 it is just gonna be aligned by normal which is not good as well lol
30Mins later found a solution:
I think I have found the solution. Just rotated FOREST NODE itself then click on update or tick auto update in surface panel and using UV Mode with Slider to 100 pointing upwards. Thx hope it will be helpful for anyone with the same problem in the future
« Last Edit: June 23, 2014, 02:28:21 pm by RC2463 »
