Author Topic: Automation of Library Creation  (Read 4518 times)
damien11235
« on: August 23, 2019, 06:41:19 pm »
I am creating a new library.
1. is there any way by which i can select a folder and all the max files can be chosen to import the 3d objects as separate  library object.
each of my files had only 1 object inside it and its name matches that of the thumbnail.
i know that i can do that as long as all the objects are in 1 single file but not from separate files.
Thank you,
Re: Automation of Library Creation
« Reply #1 on: August 23, 2019, 07:41:13 pm »
Sure,
Lets create a Forest Library for this free Birches library:
To create image thumbnails I have used HCG Asset Manager
1. Lets Create Folder library structure to put our items:
2. Choose Import Objects...:
3. Choose all Max files:
4. Select all and Import:
5. Save Current library:
6. Choose "Open In shell":
7. You will see an empty thumbnails folder:
8. Copy/Move Your thumbnails to this folder:
9. Refresh Your library in Library Browser:
10. Still no thumbnails? Lets check object properties.
It expects to Thumbnail filename to according to object name, not max filename:
Let's add "_" to jpg filenames:
11. Refresh the library again:
Hope this helps.
