Author Topic: Horizontal Shadows on objects  (Read 31473 times)
UF7753
« on: November 26, 2007, 03:40:46 pm »
the horizontal shadows do not cast across objects. the vertical do as you can see from the image below. so is there something i'm missing or is this a limit of forest pro at the moment?
Re: Horizontal Shadows on objects
« Reply #1 on: November 26, 2007, 07:52:09 pm »
We cast horizontal shadows using a fake plane, placed by default at 5% of the tree's height from the base of it. So, the objects above of this plane are out of the shadow area.
Try increasing the Z Offset value in the shadow parameters, to move up the shadow plane. Although this fix is very dependent of the scene, may be useful in some situations.
UF7753
« Reply #2 on: November 27, 2007, 12:53:08 pm »
thanks for the reply. i will try this later when i get a chance. i do not plan to place objects in this position often and i suppose i could leave off the horizontal shadow as an option.
if i remember correctly, when i increased the z% the shadow started to move in the direction that the light creating the shadow was pointing. i could create another directional light pointing straight down to cast the horizontal shadow, so when i increase the z% it will not move in the (x,y) axis. if this works i'll post back.
UF7753
« Reply #3 on: November 27, 2007, 03:31:31 pm »
some success. i found that using a second light with raytrace shadows for the horizontal shadow works in the sense you can increase the z% without the shadow moving in the x,y plane. i had to vary the shadow density to get the xshadow to a similar raytrace shadow.
this is probably getting a little complex, because i need to add another light for GI and 3 lights are 1 too many, i think.
