Author Topic: Backward compatibility  (Read 12697 times)
Ronen B
« on: December 30, 2009, 01:14:36 pm »
I opened and old scene and now it looks for a forest .dlo file pr something like that even tough i have the new forest pro installed... and all the forest objects in the scene are gone! is this a known issue?
How can i make the scene work exactly like before?
Cheers
Re: Backward compatibility
« Reply #1 on: December 30, 2009, 06:49:19 pm »
Your scene uses objects created with Forest 2. Because of significant differences between versions, Forest 3 doesn't handle the objects created with Forest 2, although you can have both versions installed simultaneously.
You can download from User Panel->Previous versions the latest Forest 2 release so you can to open old scenes. However, this version of the plugin is supported only to 2009.
I've also attached a maxscript file to convert Forest 2 objects to Forest 3. These scripts are unfinished and don't handle all existing parameters, but would help you for upgrading your scenes.
