Author Topic: Bad Forest  (Read 3870 times)
Bobby Parker
Bad Forest
« on: May 03, 2016, 05:04:53 pm »
I am finding myself rebuilding a lot of my Forest stuff. Things that once worked, stops working, and I have to delete it and do it again. Once I rebuild it, it'll work.
Re: Bad Forest
« Reply #1 on: May 03, 2016, 05:14:52 pm »
Hi, what problem did you get exactly ?
Please, send us some of the problematic objects and we'll check them.
Bobby Parker
Re: Bad Forest
« Reply #2 on: May 05, 2016, 05:54:48 pm »
In my case bushes stop rendering when they were rendering just fine earlier. I have to delete it and add it again for it to work. When it happens again, I'll send it.
Re: Bad Forest
« Reply #3 on: May 05, 2016, 06:19:29 pm »
That would happen rendering objects created with a non-legitimate license.
If you are using a third-party library, problem may be there. We can check it if you like.
Bobby Parker
Re: Bad Forest
« Reply #4 on: May 06, 2016, 09:45:28 pm »
How do I check if my license is working properly? You can see my license through my user name (UC3472), I am assuming.
Re: Bad Forest
« Reply #5 on: May 07, 2016, 09:26:52 am »
According to our logs, your license is activated correctly.
But the problem would be in Forest objects created with other licenses (for example, third-party libraries or scenes). In this case, only we can check them.
Bobby Parker
Re: Bad Forest
« Reply #6 on: May 12, 2016, 02:10:24 am »
I am not sure I understand. In this case, it just some plants. I am past that project, but I'll let you know if it happens again.
