Author Topic: quick quesion - maxscript to add / edit items in the areas list?  (Read 3225 times)
Screenscene vfx
Heya folks!
I've to do a mass edit of a scene with a lot of forest objects so I can break it up to split a render for efficiency. I'm trying to script a few things to add a spline to the areas list of all the forests and use it as an exclude but I can't get forest to behave on a simple test scene. I've tried copying and pasting from the listener which has 31 entries and editing to niclude my new object as a variable name but no go. I'm mainly looking at the arnodelist and arnamelist arrays but having no luck. Any ideas? There doesn't seem to be anything in showinterfaces for addnig bits into the areas list either.
Any help much appreciated!
John
Screenscene vfx
Re: quick quesion - maxscript to add / edit items in the areas list?
« Reply #1 on: April 25, 2017, 11:09:33 am »
You can also tell the quality of my coding from the amount of spelling mistakes in that post :D
« Reply #2 on: April 26, 2017, 11:02:51 am »
To add a new Spline Area to existing Forest object, it's necessary to raise .count vales for multiple Forest properties. For example in a following way:
areasSum = $.aridlist.count
$.aridlist.count = areasSum + 1
$.pf_aractivelist.count = areasSum + 1
$.arnamelist.count = areasSum + 1
$.arnamelist[areasSum + 1] = ""
$.arnodelist.count = areasSum + 1
$.arnodenamelist.count = areasSum + 1
$.arnodenamelist[areasSum + 1] = ""
$.artypelist.count = areasSum + 1
$.arincexclist.count = areasSum + 1
$.arresollist.count = areasSum + 1
$.arslicelist.count = areasSum + 1
$.arslicetoplist.count = areasSum + 1
$.arwidthlist.count = areasSum + 1
$.armaplist.count = areasSum + 1
$.arscalelist.count = areasSum + 1
$.arthresholdlist.count = areasSum + 1
$.arselspeclist.count = areasSum + 1
$.arspeclist.count = areasSum + 1
$.arspeclist[areasSum + 1] = ""
$.arpaintlist.count = areasSum + 1
$.arflafdenslist.count = areasSum + 1
$.arflafscalist.count = areasSum + 1
$.arflinvlist.count = areasSum + 1
$.arboundchecklist.count = areasSum + 1
$.arshapelist.count = areasSum + 1
$.arobscalelist.count = areasSum + 1
$.arsurfidlist.count = areasSum + 1
$.arsurfidlist[areasSum + 1] = ""
$.arzoffset.count = areasSum + 1
$.aridlist[areasSum + 1] = areasSum + 1
$.arnamelist[areasSum + 1] = "newSplineArea"
$.arobscalelist[areasSum + 1] = 100
Then, you can add & define the spline object by:
$.arnodelist[areasSum + 1] = splineObject
$.arnamelist[areasSum + 1] = splineObject.name
and set it to the Exclude mode:
$.arincexclist[areasSum + 1] = 1
Hope that helps.
Screenscene vfx
« Reply #3 on: April 26, 2017, 11:15:44 am »
Just got the same Michal, it was a dumb issue with error checking on picking up the forests that got me and not the forest code itself - much appreciated for the reply and apologies for the panic on twitter to Paul!
