Author Topic: Forest Pack effects - OffsetMap  (Read 22535 times)
DZIOMO
« on: June 23, 2020, 08:51:19 am »
Could You explain where can I find the OffsetMap in Effects editor, or what should I do to make it from scratch.
Here is the example from the tutorial -
https://www.screencast.com/t/WZvDxsq4pDt
Best,
Michal
Re: Forest Pack effects - OffsetMap
« Reply #1 on: June 23, 2020, 09:25:13 am »
to make simple anitmation effect from scratch use this code(You will need to add "OffsetMap" to the effect Parameters ):
Code: [Select]
vector scale = evaluateTexture(OffsetMap,fpItem.distUVW);
fpItem.scale.z = fpItem.Scale.z*scale.z;
Added a max file for Your reference as well. Hope this helps.
