Author Topic: Report Bug  (Read 24152 times)
ES4214
Report Bug
« on: June 22, 2020, 06:28:26 pm »
hi. I want to report a bug in 3ds max corona render.
when we edit the material of the object, in forest pack no update.
we need manual click on clear in material button in geometry part.
are we have a script? because this work take us very long time
thanks
Re: Report Bug
« Reply #1 on: June 23, 2020, 07:56:12 am »
Would You please provide more information?
I have checked but could not reproduce the issue.
Could You please send us Your simplified scene and steps how to reproduce the issue.
Thanks for reporting.
ES4214
Re: Report Bug
« Reply #2 on: June 23, 2020, 12:11:54 pm »
hi again. thanks for the response
we create a forest scatter from a tree.
some times when we edit the source tree object shader, not happen new shader in Forest scatter ...
we have 2 ways.
1 - reassign the tree from the geometry part
2 - in geometry part in the material we should click on the clear button to clear the material slot part.
so it's a very big problem. in my scene some time I have over 20 forest scatter with 4 to 10 separate objects.
it very gives us time to one by one we click on clear button.
Re: Report Bug
« Reply #3 on: June 23, 2020, 01:04:42 pm »
there is something You do wrong, are You editing automaterial ?
please send us Your scene and steps what You do. We will provide a solution.
ES4214
Re: Report Bug
« Reply #4 on: June 28, 2020, 10:14:16 pm »
hi again
let me explain
for example
we have some Forest objects. so they have material and everything is ok.
when ever edit objects for Forest node they complete ok and no problem
but every time we merge the same object from another file with an alternative material, etc ... the 3dsmax ask a question
Duplicate material...
we need to merge material because we need update material from Forest object
but not update in Forest node.
we should press clear bottom in Geometry part to reload new material
so in a normal scene, I have over 20 forest and it took me many time.
Re: Report Bug
« Reply #5 on: June 29, 2020, 09:13:40 am »
OK, I have added clear material option in ForestPack Toolbox utility.
ES4214
Re: Report Bug
« Reply #6 on: June 29, 2020, 03:24:20 pm »
you are the best company....
my best buy is forest pack license!
I hope one day I can buy railclone.
