Forest Pack => Forest Pro (*) => Topic started by: ldotchops on February 23, 2022, 12:00:15 am
Is there a way to use more than one object for bend by object effect? making a second effect doesn't work. Also is it just from the pivot, not the surface itself? I wanted to use a long rectangle that sweeps across in a line.
It also doesn't seem to work very well with in UV mode on bent surfaces. they bend in strange ways and the falloff seems to fail.
I'm afraid, that multiple objects aren't supported by this effect, which is using just the positions of the object (its Pivot Point) as you‘ve pointed out. Instead, creating a Spline Excluce Area(s) and using the Bend by exclude area effect should do the trick ;)
