Forest Pack => Forest Pro (*) => Topic started by: Fabrice on February 05, 2018, 07:51:36 pm
Title: Bending/shaking a few trees
Post by: Fabrice on February 05, 2018, 07:51:36 pm
in my scene a helicopter cflies above a FP forest. So I'd like the trees beneath the helicopter being shaked more and more as it comes closer (and idealy break some of then).
That should be possible with a noise + vol. select. But when I add modifier on top of the FP object it simply disappears.
I read somewhere to go to Display/mode/meshe but doing this also make the FP object disappear.
Fabrice
Title: Re: Bending/shaking a few trees
Post by: amitgedia on February 06, 2018, 08:47:32 am
Hi Fabrice,
I think with your situation you can try to use forest effects along with the method that you have mentioned
You can have more indepth knowledge of Forest effects from the following link
https://docs.itoosoft.com/forestpack/forest-plugin/effects/effects-library
and also
https://docs.itoosoft.com/forestpack/forest-plugin/effects/effects-examples
Hope this helps
Amit.
Post by: Fabrice on February 07, 2018, 11:24:08 am
Hi Amitgedia.
I will try the effects, seems to fit my needs.
Thanks for helping.
Fabrice
