Author Topic: Reference Points  (Read 5060 times)
rob_aspray
Reference Points
« on: February 07, 2018, 01:00:02 pm »
Hi all,
Wondering if someone has the answer to this issue I'm having.
I'm trying to create trees using reference objects, however the trees are created on the top and not on the pivot which is on the bottom.
rob_aspray
Re: Reference Points
« Reply #1 on: February 07, 2018, 02:29:26 pm »
....think I might have found the solution. Reset the xform on the objects seems to have worked.
« Reply #2 on: February 08, 2018, 09:52:20 am »
You should use the Creation Tools > Reference Objects > Distribute Using: Pivot option. If the problem persists, I would suggest you to double check the Pivot Point positions on used references objects and the distributed item too.Thanks in advance for any further comments.
rob_aspray
« Reply #3 on: February 08, 2018, 11:02:45 am »
Thanks Michal,
I never thought of doing that but it sounds like a good option in the future.
Cheers
