Author Topic: Restrict Forest Pro instances to Sub material?  (Read 8527 times)
QM3423
« on: June 11, 2011, 05:25:36 pm »
I think this may be an easy question.  I have a mesh with a Multi/Sub object material applied.  I want to apply Forest Pro to that mesh but only have the forest pro plant instances be on the sub material with ID #6.  Is this possible?
Re: Restrict Forest Pro instances to Sub material?
« Reply #1 on: June 11, 2011, 06:59:50 pm »
Why not apply a material modifier with ID 6 to the mesh before using it on Forest ?  (or create a copy of the mesh if you don't want to modify the original object).
QM3423
« Reply #2 on: June 11, 2011, 07:16:50 pm »
Thanks for the reply. I am new to the plugin. So can i tell Forest Pro to only apply plants to the mesh on faces that have a material ID 6?  I am sure this is staring me in the face but i cannot figure it out.
« Reply #3 on: June 11, 2011, 07:55:19 pm »
Please, forget my last reply, i misunderstood your question.
Unfortunately, there is not any option to use Forest on specific faces of the surface. You should to create a separate mesh with the faces of material ID 6, and use it on Forest. You can hide this mesh from the render, once the plants are created.
