Author Topic: Tree Height Issue  (Read 3885 times)
OQ2133
Tree Height Issue
« on: July 05, 2014, 06:15:36 pm »
I am a bit confused, no matter what internal units i have, or display units, when i add the free sample HQ trees such as the palms etc and attach them to a spline, they come in around 5m tall.
I have "get size from file" ticked, and all other settings as default.
I can use global scale to get them to look more realistic heights but surely they were modelled to a real scale? If so how can i get them to come in at that scale?
Re: Tree Height Issue
« Reply #1 on: July 06, 2014, 08:35:47 am »
The height is correct: 5m for Canary Date Palm. You can check the original scenes at C:\Program Files (x86)\Itoo Software\Forest Pack Pro\lib\Free Models\HQPlants Free.
These models are included by courtesy of 3D Mentor, so i cannot tell you what reference they used for modelling. According to wikipedia, this palm is usually a bit higher, but 5m doesn't seem too wrong.
OQ2133
« Reply #2 on: July 06, 2014, 02:32:09 pm »
According to the wikipedia link you posted:
"Phoenix canariensis is a large solitary palm, 10–20 m (33–66 ft) tall"
(Which i guess explains why i need to global scale everything by 300-400 to get it to look right)
I assume that this is an issue more to do with 3rd party providers of accurately scaled models more than anything with the plugin then?
« Reply #3 on: July 06, 2014, 05:18:01 pm »
That's it. Forest just uses the model as it. In any case, you can scale the model in several ways:
1) Locally to the item selected in the Geometry List:
- Turn off "Use Object Dimensions", and adjust the size using "Width/Height" parameters.
2) Globally to all Forest objects in the scene:
- Once imported, unide and unlock the layer "forest_templates" where the models are stored.
- With a Forest object selected, use right click->Select Forest Custom Object.
- The 3D model is selected, scale it as desired.
- Select the Forest object again, click Display->Update All.
- Lock and hide the templates layer.
3) Persistent for all scenes:
- Creating a custom library and a copy of the item.
- Scale the model in the source Max scene.
- Use the new item  in your scenes.
