Author Topic: Better solution to use closed spline as open  (Read 6019 times)
GT4505
    • claar.be
« on: August 15, 2017, 04:56:55 pm »
I'm creating some forest zones, at the edges I'd like some extra vegetation.
It would be handy to scatter those on the spline, with a certain width, as if the splines that generate the forest were open for these extra vegetation objects.
I found this thread: https://forum.itoosoft.com/index.php?topic=2102.msg7769;topicseen#msg7769
But it's already from some years ago.
Maybe there can be done something with the effects tab?
Thank you
Pieter
Pieter van Stee
Re: Better solution to use closed spline as open
« Reply #1 on: August 15, 2017, 05:49:38 pm »
I'm afraid at the moment the advice from the other post is probably the best way. However feedback like this is helpful so I'll add an option to treat closed splines as open to the wishlist for discussion in the next version.
Paul.
GT4505
    • claar.be
« Reply #2 on: August 15, 2017, 07:50:45 pm »
Hi Paul,
Would be nice to have this feature.
Because then we can use just one spline, for both.
So you don't have to think about changing multiple splines to keep everything linked and up to date...
Thank you.
Pieter
Pieter van Stee
