Author Topic: Big grass fields tips  (Read 16354 times)
OU9561
« on: October 16, 2024, 02:36:31 pm »
Hello everyone! do you have any tips or suggestions on how you get big expanses of grass field to look realistic? using the lawn presets when you look them from far away, you always get a bit of a spotched look, that doesn't look very realistic.
Something like this is what I'm trying to achieve:
Thanks a lot!
RealViz
    • RealViz
Re: Big grass fields tips
« Reply #1 on: October 16, 2024, 03:52:13 pm »
The first step is to use FP_Color and color the grass according to the texture with the "As texture on surface" setting. The second step is to resize only in Z using the map in transformation and thus get "trampled" areas. There are still more steps, but for now try this.
