Author Topic: Location Issue  (Read 2747 times)
Sketchrender
Location Issue
« on: January 15, 2016, 11:55:18 am »
I have a sphere,  I apply a forest pro item.
Its appears way off  and not on the object.
I have the active pivot point of the both the object and scatter object centered to their individual objects.
So any idea why this is happening.
Thank you
Re: Location Issue
« Reply #1 on: January 15, 2016, 12:12:38 pm »
Usually, I would suspect there's something wrong with the Pivot Point position of used Item - Custom Object as Forest Pack uses it to determine where used geometry should be placed (this position might be later adjusted for example with the Geometry - Custom Object - Z Offset value).
As you're saying, that "... I have the active pivot point of the both the object and scatter object centered to their individual objects ...", would you mind to send your scene (containing problematic model & Forest object) through WeTransfer to support@itoosoft.com to check it here? Thanks in advance.
Sketchrender
Re: Location Issue
« Reply #2 on: January 15, 2016, 12:39:14 pm »
Yes
Your were correct, that's what the problem was.
Thank you always get an answer here.
Very much appreciated.
Phil
