Author Topic: Border problem  (Read 3551 times)
lingrenddd
Border problem
« on: August 04, 2021, 07:35:45 pm »
Hi!
I have two kinds of grass (green and yellow) on one side, they are two forest objects, they have neat borders, now customers want two grass to show the effect of transitions somewhere, and the rest of the place also keeps White border, what is the way? Please see the diagram.
Finally, I with 3DS MAX files.
« Last Edit: August 05, 2021, 10:53:04 am by lingrenddd »
Re: Border problem
« Reply #1 on: August 05, 2021, 02:07:00 pm »
Thanks for the interesting question. It's quite tricky, but I think you can achieve what you need just using a combination on include and exclude areas combined with falloff.
First of all you'll need 3 splines. A middle section (the ellipse in this example) that both areas share as an Include area. Because this area overlaps though, you'll need to exclude it first. Then outside of that you'll need a spline each to exclude the two FP generators. Here I've added one about and one below. You can then increase the Exclude falloff values for each Fp object to create a gradient in the middle zone
Note that if you are using other exclude areas in your object, you'll need to override the falloff effect for them by using the Falloff Effect parameters
This image illustrates how the 3 splines are used for the red Forest object.
And this image illiustrate how the splines are used for the green Forest object
A sample file is attached.
I hope that helps,
lingrenddd
Re: Border problem
« Reply #2 on: August 05, 2021, 02:13:23 pm »
Thank you very much, I study this document.
damien11235
Re: Border problem
« Reply #3 on: September 08, 2021, 06:05:14 pm »
Wouldnt it be much easier to use the paint feature along with the splines rather than complicating it with fall offs?
