Author Topic: Install FP 4.3.4 on XP  (Read 3959 times)
Rzk
« on: January 05, 2015, 12:37:57 pm »
I've just installed the last version of FP (4.3.4) on all our Win7 PC without a single trouble.
But when I tried to install it on our winXP PC nothing happened.
I double click/ right-clic-launch  :  "ForestPackPro434.exe",   the xp hourglass icon appears for about 6 sec,  then nothing happens...
No installation setup.
Is FP 4.3.4 still supporting XP ?
Any idea what could cause this?
ಠ‿ಠ  Knowledge is power ಠ‿ಠ
Re: Install FP 4.3.4 on XP
« Reply #1 on: January 05, 2015, 12:50:47 pm »
Please try to run the installer with administrator rights (right click on file and then Run as administrator).
If you are still unable to open the installer window, please try following steps:
Right click on the installer file and select Properties. Click on Learn more about program compatibility link on the Compatibility tab and follow Program Compatibility Wizard step by step. That should solve the problem.
Kind regards,
Rzk
« Reply #2 on: January 06, 2015, 02:54:25 pm »
Thanks alot  it worked  ;D
