Author Topic: Wood trellis wall  (Read 3297 times)
Pierre
    • Studiosezz
Wood trellis wall
« on: January 11, 2017, 06:48:33 pm »
I try to build a wall with a wood trellis like the example "trellis.jpg". I'm using forest but maybe railclone would be better ?
I'm using UV mode because the trellis is build on 3 perpendicular faces. At the angle I don't know how to cut the branch in uv mode.
Can you explain me how to do this?
Thank you
Pierre
Studiosezz PARIS
www.studiosezz.com
Re: Wood trellis wall
« Reply #1 on: January 12, 2017, 12:31:26 pm »
Well, with Forest Pack you'll find corners & openings hard to solve and usually you'll need to combine multiple Forest objects (you might find handy the UV mode - you should "remap" the UV coordinates of used surface precisely to get desired result).
In this case you may archive better results using very simple style within the RailClone plug-in (as that will adapt the source geometry), which will handle those "problematic" places easily.
Hope that helps a bit.
