Author Topic: Forest Libary Map Paths  (Read 2789 times)
MU3245
« on: December 09, 2023, 10:35:12 pm »
Using 3DS Max 2023.3 and Vray 6.2 and Forest Pro 8.2.5
For some reason my library(s) are no longer recognizing the maps folders. I have to add each path manually in "Configure Project Paths".
I have attached a screen grab showing an example of my Library structure . I have been using this for years without a problem. Now I have this trouble.
Have I done something wrong or....?
« Last Edit: December 09, 2023, 10:36:44 pm by MU3245 »
Re: Forest Libary Map Paths
« Reply #1 on: December 11, 2023, 08:59:48 am »
Please double-check your Library Browser > Preferences > Options - for the best performance, by default, the "Add 'maps' folders to 3DS Max texture paths" feature has both the "Only Built-In Library ("Forest Library")" and "Exclude network paths" options checked - disabling these should do the trick (the Forest Pack plug-in will also search in your "custom libraries" and should be able to add them automatically).
« Last Edit: December 11, 2023, 09:16:25 am by Michal Karmazín »
MU3245
« Reply #2 on: December 11, 2023, 05:30:04 pm »
Thank you Michal. I have disabled those two options and believe that was likely the trouble. If further problems I will follow up, otherwise thanks for your help!
