Author Topic: Brick wall with 4 different brick sizes and materials  (Read 3956 times)
Robin Arnecke
« on: September 16, 2018, 04:05:56 pm »
i`d like to build a garden wall with different sized and shaded natural stones. so i modelled these four types and tried to distribute them on a spline with forest pack pro.
Unfortunately i can only enter a value for the spacing, which doesn`t seem to take the different dimensions of the stones into account, so i get overlapping geometry.
What i would need is some sort of a collision button, which is only in image mode available. So is there way to do this kind of wall in forest pack pro ?
I also tried it with rail clone pro, but didn`t find the right parameter for using different sized bricks and having equal gaps between them.
I don`t use the plugin vrey often, so there is a lack of knowing it very well. Can someone please guide me how to build up a setup in RailClonePro, if forest pack pro isn´t the right choice ?
Can i use forest color in conjunction with a railclonepro setup ?
'I tried to make a new post in the Railclone Pro forum, but can`t create a new thread. Do i need a active subscription for creating new threads in the forum.....this would be very strange.
I attached a screenshot with a FPP setup in spline mode for distribution, where i afterwards adjusted the overlapping / gaps of the stones manually in edit mode...but this is way to time consuming, so i would
like to manage this completely procedural either with FFP or RCP.
Thanks for help
Robin
Re: Brick wall with 4 different brick sizes and materials
« Reply #1 on: September 17, 2018, 10:29:35 am »
Unfortunately this task is not for ForestPack, but it is what RailClone does very well.
I granted You rights to post in RailClone Pro board.
Please post a new thread there with attaching Your starting file and we will help You there.
« Last Edit: September 17, 2018, 10:36:37 am by Rokas »
