Author Topic: Bug: distribution map doesn't update if...  (Read 6566 times)
George
« on: March 28, 2011, 01:47:49 am »
If you wrap a bitmap in a color correct map (Max's or the Orbaz one) and use it in the map slot of distribution settings, it doesn't update until the second render. You can replicate this by doing what I said, saving the scene and re-opening it. It doesn't render correctly the first time, but is ok the second time.
Re: Bug: distribution map doesn't update if...
« Reply #1 on: March 28, 2011, 06:54:50 pm »
Thanks for reporting, i can confirm there is a problem with ColorCorrect. We are currently working to isolate the bug.
Updated: we just found and fixed the problem. The fix will be included in the next beta version.
« Last Edit: March 28, 2011, 07:08:32 pm by Itoo »
